What are the main differences between Kinetix and Powerflex systems?
helphelphelp
Feb 2020
Canada
41
New to servo drives, wondering what the main functional differences are between the two types of servos. Any help even the most basic is very helpful.
Thanks!
Not experienced with servos, but my understanding is that Kinetix drives are specifically designed for servo control whereas the PowerFlex drives are for (non-servo) induction motor control.
Powerflex will simply use a run and speed command to make a lower torque move. Simply running a motor until told to stop.
Kinetix will use high torque and precision move commands to get it done. Instead of just start and stop with a speed reference. Its told exactly where to go and how to get there with each move being fully controlled in profile.
I just finished up my first Kinetix project last week. It was only a simple depositor machine but t was a damn good learning experience. It turned out to be much simpler to program the logic than I had thought before getting it started. No issues to speak of though after I figured out that I was running it way to fast in the beginning. These things will fly. The machine is super accurate with its dispensing as well!
You will like the Kinetix.
335
Hello Everyone- I'm working on a new network deployment of AssetCentre and I am not able to authenticate with the application using our...
415
TLDR: I try to establish the OPC communication between Kepware OPC DA Client to ABB 800xA OPC DA Server. In the Kepware OPC quick client of poll...
869
Main rack contained power supply 140cps52400 and 140cpu43412A and RIO HEAD 140CRP93100 in addition to another I/o cards . Another remote rack...
1,886
Hi Installing Plant Scada 2020 on domain Encountering heaps of issues. Completed fresh server install and domain. Noticed some of the...
1,748
