what are the main differnces between NC & CNC ??
magdyfayad
Aug 2007
cairo
245
if i have a PLC and a panel , is it called then NC ?? or when called NC ??
do CNC must operate with G-code or what ?
thanks
CNC(as well as NC)require more than just a PLC. Although you can use a PLC to control servo motors, the shapes that can be made are limited (typically point to point) A CNC machine is used to cut or otherwise form materials into complex shapes using multiple axis with servo motors acting in tightly controlled co-ordinated motion. In order for the process to be accurate, the control must be able to process the desired tool paths into a motion path(quickly and accurately)that must take into consideration tool size, tool edge wear and shape, desired speed and feed rate, etc. A PLC (as far as I know)is not capable of this type of complex motion control. All (again, that I am aware of) CNC machines have some sort of PLC imbedded that will control things like coolant on/off, chuck open/close,etc. But the bulk of processing power is used for the motion/speed control of the tools.
Others can elaborate more on this, as I am just a ROOKIE..
NC = Numerical Control. The commands are gives as sequences of numbers.
CNC = Computer Numerical Control. You can enter commands as mnemonics, which in turn are translated to numerical control sequences.
NC can (up to a certain level) be done by a PLC, CNC requires (almost always) a computer.
Kind regards,
311
Hello Everyone- I'm working on a new network deployment of AssetCentre and I am not able to authenticate with the application using our...
408
TLDR: I try to establish the OPC communication between Kepware OPC DA Client to ABB 800xA OPC DA Server. In the Kepware OPC quick client of poll...
860
Main rack contained power supply 140cps52400 and 140cpu43412A and RIO HEAD 140CRP93100 in addition to another I/o cards . Another remote rack...
1,868
Hi Installing Plant Scada 2020 on domain Encountering heaps of issues. Completed fresh server install and domain. Noticed some of the...
1,744
