What color should a STOP button be?
jdbrandt
Oct 2002
Pennsylvania
1,203
Machine: A machine that produces a product. (NOT a power plant)
Function: When this button is pressed, the machine should discontinue the production that it is doing, and all motion should stop.
Yes, we would call this a Normal Stop.
Not, by the way, any of these names: Functional Stop, Zone Stop, Batch Stop, etc.
Just plain old stop.
WHAT COLOR SHOULD IT BE?
WHAT COLOR CAN IT BE?
WHAT COLOR SHOULD IT NEVER BE?
It "should" be red and it must not look anything like an E-Stop and must never be green or blue.
I have worked on machines with:
Stop
Power Off
Cycle Stop (at end of cycle)
Top Stop (Cycle Stop for a stamping press)
Cycle Interrupt (immediate)
and more
The one thing they all had in common was Red Pushbutton operators, never a mushroom top, never a yellow background, never latching - just RED.
According to NFPA 79, which is the electrical standard for industrial machinery:
“The preferred color for stop or off shall be RED, except that BLACK, WHITE, or GRAY shall be permitted. GREEN shall not be used for stop or off.”
Came to post this.
NFPA 79, 10.2.2.2
Does anyone know how to set the background colors of instuction blocks (TON, MOV, etc)?
139
HEllo, still satruggling with the curse WinCC Unified. See attached picture. I just want to change the fill colour from turqoise to grey and then...
482
Hello all. It's already have been discussed here and over internet, but I'd like to have your opinion again on the topic. If you physically...
17
1,612
Dumb question, Hooking up two wire reed switches out in the field. They are wired into sinking input cards. Once the wires leave the panel, do...
1,504
All, Learning simple PV animation on color table. PV should be in RED when PV < or > LR or HR PV should be yellow when PV < or > LLR or HHR
650
