What Happens if Uncharged VFD is Connected to Charged DC Bus
bodoo23
Jan 2018
Athens
57
if the dc fuse of the uncharged drive is closed when the dc bus of other drives is charged , what happens ? Is there any risk of damaga capacitor ? As I know, capacitor can stand to very high currents thanks to its nature. I know the fuse might clear but if the fuse is oversized, is there any risk for capacitor ?
In general, connecting a discharged VFD directly to a full voltage source is a very bad idea. If there are fuses in line, they will probably instantly clear, even if drastically oversized, and yes, there is the potential to damage/destroy the capacitors, as most drives don't incorporate a precharge circuit directly on the DC bus.
Thanks for your clear respond. I was thinking that the inrush limiter/precharge circuit is just for protecting the front end of vfd but as I understand from your respond, it also protects capacitor from damage right ?
When AC Powered, the charging circuit if most VFD's, especially larger ones, automatically reduce the inrush charging current to the rectifier/capacitor bank.
When powered directly from a DC Bus, unless the drive was designed with an inrush limiter, there generally is not one, as the DC Bus terminals are connected directly to the DC bus in the drive.
Hello, the PLC in question is 1769-L30ER. I have a local 4-20mA Analog Output module (1769-OF4CI), and also a remote ethernet PointIO analog...
402
Hey Everyone, I was wondering how the "Test Edits" mode works in studio 5000. I've never used it before. I read the outputs don't actually change...
1,079
Is there a difference of behavior between the PLC5 and the Logix series when it comes to JSR behavior? Assuming I do nothing to this bit...
19
2,855
struggling to find documentation on this, I have it in my head that it overwrites itself but i dont know where i have got that from. when it...
890
Hi, I am trying to understand what the result of a MOV will be. G_position_LSB= 144, Type- INT GL_O_Data[3]=0, Type- SINT...
1,243
