What is a digital input?
Don't know how you learned about analog inputs without learning about digital ones, because these are the simpler ones. Digital means only two states: on and off (or 1 and 0 or true and false). Think of switches!
Regards,
Digital inputs - in the world of PLC's - are not to be mistaken for (digital) communication as e.g. RS232.
In PLC terms, a digital input is - as jvdcande states - a "Examine if closed" input. The PLC will determine if a signal is present at the digital input terminal or not. E.g. a "START" push button.
Actually, I see the term "discrete I/O" replacing the older term "digital I/O". Either term represents the fact that there are only two discrete states, which can be represented by the digits 0 or 1 as stated above.
I avoid the term "examine if closed" because that is Allen Bradley specific.
"discrete" is used in relation to the sampling of a signal over time. The "discrete" means that the actual value of a signal between samples is unknown.
"digital" means that a signals amplitude is sampled and quantisezed into a finite numberset. That could be 0-1 for a 1-bit (boolean) value, and 0-4095 for an 12-bit (analog) value.
Apart from that, "digital" is freely used everywhere when it is actually meant to be "boolean". Have anyone ever seen a boolean input card ?
Hello, I'm looking for a dirt cheap digital display + input, that would be wired to an analog input and analog output. This would be for my home...
185
I have an application that needs a simple way for an operator to input an integer value and send it to a PLC. An HMI is overkill, but I am...
1,275
I am experimenting with a very simple program for testing purposes and not getting any movement from the servo motor. The attached program...
1,797
So I am new to the plc scene, and I am working on a machine that gets a fault, to which I think it is a overtorque fault. I did some research on...
1,981
Hello, I have a small programming task that I need help solving. I have to: * Create an analog input (4-20v)and a digital output * The analog...
45
25,176
