What is Crystal Report?
emokar
Sep 2006
turkiye
77
Scada i use (MoviconX2,Progea) uses crystal report. I have problems printing data logger windows.
While programming , when i try to generate the .rpt file, the software gives "CRW not installed or missing some runtime files" error message.
I have the example program and i am sure the problem will be solved if i could create a .rpt file.
I don't really know what Crystal Report is. Shouldn't it be installed with the scada software if it uses it?
How can i install that program? where can i find it?
Thanks...
Crystal reports is a separate reporting software, and it is also bundled with other development software. It comes with MS Visual Studio for instance. Your SCADA package must've used it and it should be installed as part of that. I would call your SCADA supplier for help if that's possible.
thanks,
i have called them and they sent me an example program. The example works fine. So i think the problem is SCADA software, not Crystal report..
Good Day, Just wanna ask if somebody had an experience working Wonderware Historian with Crystal Report as Report Generator? We have already set...
5,611
i have wonderware IAS server arrangement(insql,intouch).. my requiorement is for hourlyreport which tool i have to select? my options are crystal...
2,996
Hi, I downloaded the latest crystal reports & added a crystal reports object (Crystal ActiveX Report Viewer Control 14.0) on one of my wonderware...
1,949
Hello All, I am trying to come up with a way to print a report from an HMI screen in FTview SE Version 6. We are trying set this up so the...
6,730
Hi all, I am tring to use Crystal Reports with RSView32, I have the Data Source ODBC set up as Watcom SQL 4.0 Crystal Reports picks all the...
2,434
