What is my stupid mistake? Siemens SCL.
DLMUK
Jun 2013
Southampton
311
I am looking at analysing a sting using an FB in SCL.
I have looked at these
https://cache.industry.siemens.com/...176/v1/s7_scl_string_parameterzuweisung_e.pdf
https://support.industry.siemens.co...-different-data-type-in-s7-scl?dti=0&lc=en-WW
http://plc4good.org.ua/files/03_downloads/SCL_table/SCL-cheat-sheet.pdf
but I am falling at the first hurdle. When I try and input things like VAR and LEN TIA portal is coming up that "Tag VAR not defined". According to what the guides I am using VAR is an instruction.
I cannot see what i'm doing wrong?!
I have an S7-314.
In Portal, SCL has you declare variables like you would in any other language, in the interface at the top. You don't type out all the var/end_var stuff, you do it up top.
Been working with PLCs for a couple of decades, but almost 100% DirectLogic. Have a customer who wanted me to make a couple of simple changes to a...
1,137
New to the EcoStruxure programming software (I'm an AutomationDirect guy) and I've been banging my head against the wall trying to figure out how...
1,047
All Performed a managed ROCKWELL download before lunch. When it was finished it opened the file folder of were it loaded too. Customer called and...
1,493
I have 3 valves that I need to open for 1 minute every 30 minutes, but not all at the same time. I have one TON timer (Start Blowdowns Timer)...
4,648
I just quit my job lol 12 years of not being apricated and being treated like your nothing to them spending years learning new skills that saves...
50
11,006
