What is the Best substitute of 1747-DTAM ?
nirmitpanchal
May 2011
mumbai
Hey..
What is the best Substitute of 1747-DTAM (SLC 500 Data Table Access Module)...
Suggest plz...
what can be replaced with it?
either Panel-view ?
I have purchased some from spectrum but it depends on your specific model.http://www.spectrumcontrols.com/soi.htm
EBay
I have also replaced them with panelview 300 standard which is going silver /obsolete now also. PV Plus and component have similar units along the same size. You will have to reprogam no matter what method unless you find a direct replacement on EBay or Radwell.
EBay
Thanks for reply
Seems Meaningful...
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
512
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
626
I am going to need to use HART multi-drop in order to handle a series of Vega Radar units. There are a lot of options and I'm wondering what...
265
Out of interest, I'd like some thoughts on what would be considered best practice with regards to a 2-position turntable control scheme (see...
17
1,158
Hello colleagues Anybody knows, what could be the best or a better option to bring with you when you are in service at factory to connect via...
269
