What is the difference between PLC-5 modified and non modified version?
Just guessing....
There were "secure" versions of the 5/15 and 5/25 known as 5/16 and 5/26. Perhaps that is what they're referring to. I have no idea how they were "secured", but apparently prevented unauthorised program modification.
Gerry said:
Just guessing....
Could it be, master password (by Rockwell) cannot work in secured PLC (like CLX). The normal SLC/MLX can be override by a Master password by rockwell, no matter how OEM locks it :)
It doesn't have to do with security.
The "R" version of the PLC-5 Classic had a special jumper that disconnected the RAM and the real-time-clock from the battery when the chassis power was shut down. I don't know why they wanted it, but A-B built this variation for one specific Japanese customer.
The controller is otherwise totally firmware compatible with ordinary PLC-5 Classic controllers.
This means that the program in the RAM and clock will all be resetted :) when the power is down?
I have a Automation Direct Click Plus that you can buy option CPU slot modules for input/outputs. The slot modules have the options of sinking...
2,851
Hi All, I am starting a project that contains RTU from SCADAPack 474. However, I have no experience with this equipment, I am familiar with...
3,222
Hello, Do you know what is the difference between the PID controllers PIDFF, PID1 and PIDP1 in a Schneider PLC? I have to modify a PLC program...
1,749
HI all, I have exported csv files from one of the application which was build in factory talk view. I'm seeing 1600 tags almost and doesn't...
2,346
I was just wondering why a setup would be referred to as a DCS rather than just a standard PLC system? I was on a site the other day and it was...
2,083
