What profibus scanners are used with Siemens S7 200 PLCs ? thanks
The Profibus module for a S7-200 is a EM277 Profibus DP Slave Module. Part # 6ES72770AA220XA0
Note: The S7-200 can only be used as a profibus slave.
S7-300 and S7-400 can be used as profibus masters. I know the models S7-300 and S7-400 the Com port on the CPU is also a Profibus port. Several Models of both have 2 Com ports on the CPU.
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
184
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
84
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
108
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
319
Hi Folks, I am new to the S7-300 and the whole Profibus communication. And I just wonder that can you connect a S7-300 module to a Beckhoff Bus...
318
