What version of SLC500
Hi
Thanks for the reply guys.
Ken_Moore I did look into those smart relays and I even downloaded a software that is used to program them called "Zelio Soft 2" and I had a hard time doing what I needed them to do. Timers in this program don't have the DN bit or any other bit that Allen bradley PLCs use. For example I need to do this.
Turn ON output 1
Delay 1 sec before proceeding to next step
Turn ON output 2
Turn OFF output 2
Turn OFF output 1
.... repeat the process
Also i need to use a photo-sensor so if every couple of seconds the part doesn't come out the program would stop the operation (means something is jammed). I had a hard time programming these smart relays it seems like you have to do something extraordinary to accomplish this. Maybe I'm wrong since I don't have much experience with programming these smart relays. Any feedback from you guys is appreciated.
Thanks.
Hi All I have just started a project to convert one of our machines from SLC500 to CLX5000. One of the first steps in the Rockwell guide was to...
1,993
Has anyone used the tool from Schneider to convert an RSS file for an SLC to Unity Pro? Curious to know how it went. Their sales brochure made it...
1,387
Hello I am relatively new and working on converting a piece of code from logix 500 to logix 5000. I used the conversion tool and it did a pretty...
2,456
I am working on a conversion from a SquareD PLC to a SLC series PLC. I have run across one issue that I can not seem to overcome. The older system...
1,678
Hi, newbie here. Beside contacting an AB rep. How do I find out what is the lastest OS for my SLC 05/04 (16byte version) processor? I want to...
2,726
