when recieving data from a device how do u pick data u want/ Ignore the rest
Snide
Oct 2005
Pittsburgh
73
I need to grab data out of an array string for example, I'm reading in MYArray.ReadString[0], for example reading...
MYArray.ReadString[0] *
[1] a1
[2] a2
[3] g
[4] k
[5] _
[6]a number
[7]a number
[8] CR
[9] lf
I need to read [3] to [7] i don't care about the rest of the returned data. how do i grab just that data?
Amy
Does the data always show up in 3-7 orm can it show up in other locations? If it is always in 3-7 you can copy out of the base array into another array. For example:
COP(MYArray.ReadString[3], ArrayEvalString[0], 5)
If you don't know where the data string is but it starts with a known character, you can use the FIND instruction to locate the beginning of the data and use that as the base array element for your copy.
Keith
I know where the data is coming in for exp:
Data.ReadString[0]
about the 3 to 7 all the time no, each question i ask gives a different response, different lenghts, i do know the start and end of every string.
I know what part i want to grab, also, the string comes in at Dat.ReadString [0], could you show me an example of a copy, if that's what you suggest exp sorce= dest= length= i tried some stuff but i'm not sure i'm doing it right.
thanks amy
I'm sorry, i see your example
oh, i think i get it except i want to make sure on one thing the Dest...how did you set that in the User-Defined data types?? what would you pick for setting?
Hi, i don't know if this is a right place for this but does any one have an idea on how i can receive messages from a phone to a PC, send the data...
1,774
I'm using ICX HWC35 cellular gateway with Allen Bradley 1769 L33ER PLC for messaging purpose Already upload the AOI instruction to the project...
4,400
Hi All, Has anyone worked o a project with a master plc and other remote plc that talk to each other using sms and or GPRS and sms as backup...
2,012
Hello all! I have a micro 1100 and am trying to recieve a string from a cognex dataman barcode reader. I am not very familar with the ascii...
4,627
30
