Your I/O points are embedded in the "module-defined" tags, that always take the format Location : Slot : Tag-Type.
Location - The "name" given in the I/O Configuration tree of the parent of the I/O module for a remote connection. I/O modules in the same chassis as the controller will always be "Local".
Slot - speaks for itself, the slot number of the module in its chassis - 0 to 16
Tag-Type - Can only be I (Input to the Controller), O (Output from the Controller), or C (Configuration tag that is sent to the module to configure its operation).
An Output module will create all 3 tags I, O, and C, but an Input module will only create the I and C tags (there is no data going from the controller to an Input Module).
Inside the I and O tags is an element called "Data". Here you will find your I/O point data.
So, for example, a pushbutton wired to IN-12 of an input module in slot 7, in the same chassis as the controller, will have the "address" of Local:7:I.Data.12. Note the use of colons in the tag-name Local:7:I and dots in .Data.12 to signify "sub-element of".
Using I/O tag "addresses" directly in a program makes it hard to read, so the system allows you to create an "Alias" tag which fetches the data from that I/O tag, e.g. a tag called Start_Button could be created, as an alias to Local:7:I.Data.12, and when used in your ladder logic, makes it much easier to comprehend the code.
Also when you are looking at Tag Databases, there are 2 views.
Check-out the tabs at the bottom called Monitor and Edit.
The Monitor tab displays information on what the tag contains, and the Edit tab displays information on how the tag is constructed.
Switch back and forth between the two views and you will get the idea.
Also, at any time, if it's a white field it can be changed, if it's greyed out - changes not allowed.
