Bit_Bucket_07
If you are familiar with PLC5s and SLC500s, then you should think of the ControlLogix tag names as what you have always known as "symbols" in the older PLC systems. They are alias names for actual memory locations in the PLC's RAM. The I/O image table does have physical addresses associated with it. The address format is, for example: (Local:1:I.Data.0 - Local:1:I.Data.15) which would represent an input module in Rack 0 (Local), Slot 1, Points 0 - 15. Remote I/O Chassis will have a different name from the "Local" chassis.
When you create timers, integers, bits or other internal memory tags, then the actual memory location is transparent to the programmer.
