Which CompactLogix is the best choice for Ethernet/IP?
kittydog42
Sep 2005
Naperville
232
My choices are the 1769-L32E, or the 1769-L31 with the 1761-NET-EN1 added. Which would be the pros and cons of each? The only thing I can see is price (I don't know which costs more, however), more memory on the 1769-L32E, and an extra serial port on the 1769-L31.
L32E.
Ethernet port is part of the processor. No external hardware, no setup, it just is.
It's a no brainer IMO.
L32E absolutely. In addition to CroCop's comments above, the L32E with Native Ethernet/IP will run (communicate) at full speed. By using the NET-ENI module, you effectively limit communications to a maximum of 38.4 KBaud, which is significantly slower.
Also, if you are actually setting up communications links to other devices now (or in the future), the L32E can be directly addressed with a MSG instruction from other Ethernet/IP devices. The NET-ENI module relies on seperate programming to 'map' Ethernet port addresses to the serial DF1 protocol slaves.
If connecting (now or in the future) to an HMI, the L32E won't suffer communications bottlenecks nearly as much as a NET-ENI connected device. Even though RSLinx as an OPC server works 'mostly' well with NET-ENI devices, if you start adding too many fast polls, or too many alarm's back and forth to the PLC, you will almost certainly encounter difficulties.
-- Quick edit --
The L32E still does have a serial port, so you still have serial communications available as an option (even over a NET-ENI, though I can only imagine that you might do that to directly drive two distinct subnets). And a second point, while the actual Ethernet processor might be a bit more in cost, really, honestly, the cost of hardware, while it is a physical, absolute number price, is actually miniscule in comparison to programming time and startup-debugging time/materials.
That is the kind of information that I was looking for, thanks. I will look at pricing but I am guessing that it is a 'no brainer' as well.
Hello I need to design a panel to read (Maybe write also) some signals over modbus RTU protocol using an AllenBradley compact plc. At first i...
18
12,016
Multiple Projects coming up with lots of Touchscreen development. Am I the only one that finds the Panelview and Factory Talk ME to be severely...
4,226
While there's a few options, I just assume that the the Control/CompactLogix should be able to push/pull information over EtherNet/IP, correct...
11,660
Hi everyone, i have a compact logic 1769-L18 PLC and I'm using FTalk View ME for the display. I wanted to do some visualization on Grafana. At...
96
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
98
