which is the best one ??
The best one for me is the one I already know how to use. That allows me to get the job done in a timely manner.
If the job at hand requires that I use a tool I don't know well, I want to know that I have available a local, knowledgeable person who can answer my questions and guide me along the learning curve.
Steve's response was excellent.
I'll echo his thoughts. There are many manufacturer products that will get the job done. For me when I choose it is based on what tool I am most comfortable with. Then it's largely a factor of support - both for software and hardware. The cost of the hardware is often a factor but should be balanced with availability and support.
I would suggest you seek out system integrators in your area for recommendations. They will know what works well in your location - what can be supported and what is readily available.
In Tukey Automation Market
Looking from the customers eye: Siemens is the best automation solution always I can tell you that.
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
528
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
649
I am going to need to use HART multi-drop in order to handle a series of Vega Radar units. There are a lot of options and I'm wondering what...
276
Out of interest, I'd like some thoughts on what would be considered best practice with regards to a 2-position turntable control scheme (see...
17
1,188
Hello colleagues Anybody knows, what could be the best or a better option to bring with you when you are in service at factory to connect via...
277
