which product should i use for SCADA on DH-485 network?
mrzhao
Jun 2006
Shenzhen
26
I have a project now.
There are 7 AB SLC 503s in the plants, i would add 2 SCADA computers to monitor the SLC 503s. I am planning to use DH-485 networking for them.
which product should i use for the computers?
1784-PKTX is too expensive, could i use 1761-net-aic or 1747-PIC,1747-UIC ?
thanks for any advice!
DH485 comms will slow exponentially as you add nodes. If your two SCADA systems are carefully configured you may not see too many delays. It might be best if you used two different networks to keep the node count low on each. That would mean a NET-AIC at each 5/03 and a DH485 bridge (or two) ar each PC.
Look here:
http://www.ind-concepts.com/Allen_Bradley_PLC_Cables.htm
About halfway down the page there is a PIC replacement for an economical DH485 bridge (real serial port required).
Hello All, I'm looking for some opinions and Ideas for guarding the product entrance of a palletizing robot cell. Please see the attached...
509
Respected Members; I am going to design the PLC control system. The requirement as under: 1. Input/ Out put modules are SIL 2 certified. 24...
417
I've got an issue opening a project in TIA Portal v16. When the file is opening, I get the message that says "Optional products used in the...
719
I am new to Siemens, and just looking into their HMI software. Does Siemens have a product similar to FactoryTalk View SE? I am looking to have...
1,740
I am speccing out a system for some burner controls and the customer has two SLC500s that will need to be upgraded. There is no distributed IO. I...
25
6,580
