which RSLinx version do I need
stuman
Feb 2008
Benalla
37
If I want to connect via RSLogix 500 ver 6 through the internet to a SLC 5/05 on a customers site, what version of RSLinx do I need? Will the Lite version allow that?
I went to the AB web site but I could not understand their feature comparison chart as it convered viewing ladder and data tables in RSLinx, but I will be using RSLogix 500.
Stu
I would think any of them would... you would just need to have a VPN at you customers plant then you could communicate/see them.
You can try RSLinx lite for free to test it and that should answer your question
GiT
Linx Lite will connect just fine. I've used it to connect remotely via VPN. As far as RSLogix500/RSLinx is concerned it's no different than sitting in front of the PLC and connected to a local hub/switch.
Hello, Does anyone know if there is a portable version of RSLinx Lite (even an old one)? I am wondering as I am trying to put together some tools...
694
Hello, I am wondering which version of RSLinx I should download to use with RSLogix5000 Version 17? Thanks!
2,151
I am unable to view RSwho on the free version of RSlinx V3.90. The message I get is, "failed to show RSWho. Cant access file...
2,815
Greetings from Michigan, I want to create an HMI in LabVIEW. From my internet searches, it appears that this is feasible but I require a...
2,316
I have RSLinx 2.52 running on windows 2000, connected to a control logix through ethernet. I can see all devices in rack, and can access...
1,964
