Will my version of RSLinx suffice?
busarider29
Aug 2013
Midland, MI
399
Greetings from Michigan,
I want to create an HMI in LabVIEW. From my internet searches, it appears that this is feasible but I require a particular version of RSLinx in order to make it happen?
Here is a quote from 2010 that I found on the NI forums:
"Just be aware that with RSLinx, you need to buy at least the Classic version. The free version does not support OPC, it is just used to communicate wth the AB software. Once you create an OPC topic in Linx and point it at your PLC, you will be able to see the PLC registers using the DataSocket Browse VI."
The version of RSLinx that I have on my development laptop is RSLinx Classic Lite, v 3.81.00. Will this version work when installed on the deployment PC (PC that the LabView program will be deployed to)??
Thanks,
D
If it is using DDE/OPC to communicate, then no. Lite versions only support PLC program connections from Logix to the PLC.
Ok, thanks. That helps. Yes, I plan to use OPC. Do you happen to know what the minimum version of Linx I would need?
Thanks,
D
If your Labview HMI will use OPC, you will need an OPC Server to communicate with the PLC. There are two Rockwell product families that will do this: RS-Linx Classic and FactoryTalk Gateway.
There are variants of RSL-Classic: Lite, OEM, Professional, others? Lite is free and will not be an OPC server. You must pay for OEM (server and client on the same machine), or Professional for a more distributed approach. RSL-Classic works with PLC-5, SLC, CLX, etc.
Factorytalk Gateway is also an OPC server, and uses RS-Linx Enterprise (free) for communication to the processors. In my experience FT-Gateway is less expensive, though licensed by tag count. It has a front end when running as a service, which can be problematic with RSL-Classic.
There are third party products out there that others may comment on.
Hello, Does anyone know if there is a portable version of RSLinx Lite (even an old one)? I am wondering as I am trying to put together some tools...
688
Hello, I am wondering which version of RSLinx I should download to use with RSLogix5000 Version 17? Thanks!
2,144
I am unable to view RSwho on the free version of RSlinx V3.90. The message I get is, "failed to show RSWho. Cant access file...
2,796
I have RSLinx 2.52 running on windows 2000, connected to a control logix through ethernet. I can see all devices in rack, and can access...
1,948
I've been having the worst time trying to get my version 20 5000 to load. But I have to give some background information first. What I did to...
5,216
