rsdoran
THis has got to be a REALLY old thread.
I disagree that the answer is "counter emf", that is a bad term.
The term used at the beginning was induction, as has been explained this means that when voltage is applied to a motor...a conductor placed in a magnetic field...emf is produced. As was stated emf opposes the line current that is producing it.
What this means is that when first starting an inductive device, motor, you may see a high current at startup because the forces do oppose each other. How high the current goes will depend on the "load".
If you want to read some really detailed information on motor theory, construction etc then goto this site:
http://www.reliance.com/mtr/
