Wiegand Module?
elevmike
Feb 2004
Detroit, MI
4,012
Does anybody know of any PLC module that will accept a Wiegand input? Anybody out there that does security systems? I need something to convert the signal of one reader, to provide one of 4 outputs.
Thanks, Mike
I've never heard of a "Wiegand input", but I found THIS converter. It converters the Wiegand data to simple ASCII. Drop this into port 2 of a DL06 and you're good to go!... :cool:
beerchug
-Eric
Thanks Eric,
I'll call these people later today to see if this will work for me.
I'm configuring a security system for an elevator. Everything out there seems to provide only relay outputs, and that would make for excessive hardware and hardwiring in the panel. The product you found may just be the ticket.
I Googled for about an hour and didnt run across this.
Thanks again..
Mike
Hello Friends We have a biometric fingerprint reader F18 from ZKTeco, We need to send the User ID (a number) from the F18 to a Micrologix 1100...
2,122
Using RFIdeas Configutility, I read in raw my Hex data as follow: BBBA2164 IF I put a check mark on the "reverse wiegand bits" (not bytes), I...
11,650
Hey guys, I just wanted to see if any of the bright minds on here had any opinions on these relay interface modules. Particularly, I would love to...
24
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
257
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
120
