RFID & reverse Wiegand bits ****
BachPhi
Dec 2007
Los Alamos
640
Using RFIdeas Configutility, I read in raw my Hex data as follow: BBBA2164
IF I put a check mark on the "reverse wiegand bits" (not bytes), I will get 26845DDD from which I can extract out 5DDD which is my ID in hex.
What I like to know is What are the Wiegand bits and how did they reverse the bit to go from BBBA2164 to 26845DDD.
Thanks in advance.
All I did was Google it, since I hate to see a post go unanswered.
Weigand encoding is a 26-bit data format used by card reader devices.
http://www.identisource.net/26_bit_format_layout.cfm
You seem to be getting a 32-bit value, not a 26-bit value.
BBBA2164 hex = 1011_1011_1011_1010_0010_0001_0110_0100
26845DDD hex = 0010_0110_1000_0100_0101_1101_1101_1101
So it looks like checking the 'Reverse' box is literally reversing the order of all of the bits in the 32-bit word.
Since you say you can extract your ID value from the reversed order, it seems like the Parity bits are not being included.
I can't tell you much more, except that I suspect that you have an overlap or 'extra' data in the 32-bit element that should be masked out.
Now comes fun part. Swap Byte instruction with Reverse do not work.
I also tried BSR using unload.UL bit as a source bit without success.
The Swap Byte instruction is byte-wise or word-wise. It does not reverse the bits in order.
What exactly do you want to do ?
If you need to get the 26 important bits and ignore the 6 that don't belong, I would use the Masked Move (MVM) instruction.
I want to go from
to get
Obviously, I could use 32 separate rungs to reverse it, but I thought someone may have better idea.
I would just brute-force it. Sounds like a great use for an Add-On Instruction, if you're using the A-B Logix 5000 platform.
You can reverse all the bits by using the BSL ( SourceBit.0), then immediately follow by BSR (also SourceBit.0). It worked!! Use 32bit Looping Of course.
We have a product we are now building and are planning on using RFID tags to ID trays of product as they move through the process (5 individual...
1,453
Hi. I was wondering if any of you guys have a problem with the RFID reader/write BIS M-4A7-082-401-07-S4 from Balluff. The problem we are...
659
Good afternoon! For the past several days, I have been trying to set up this Balluff BIS018A RFID head to communicate with a Do-more BRX DM1E-M-D...
5,564
Good Afternoon, I am currently designing an HMI application that needs a screen that shows about 20 of the latest RFID [stored in PLC] and have a...
2,723
Can anyone share the hardware/software in integrating Radio-frequency identification (RFID) security on a plant floor's OEM machine HMI's? I...
2,976
