Wiegand to Micrologix?
asteroide
Jul 2010
der
158
Hello Friends
We have a biometric fingerprint reader F18 from ZKTeco, We need to send the User ID (a number) from the F18 to a Micrologix 1100
In another machines, the F18 send the User ID through Wiegand output to a Barix Barionet 100, then Barionet send digital outputs to Micrologix.
The problem is that We can not get Barix in our country.
Do you know another converter or way to send the Wiegand output to the Micrologix?
Thanks in advance
Using RFIdeas Configutility, I read in raw my Hex data as follow: BBBA2164 IF I put a check mark on the "reverse wiegand bits" (not bytes), I...
11,650
Does anybody know of any PLC module that will accept a Wiegand input? Anybody out there that does security systems? I need something to convert...
2,319
57
100
109
