Wierd thing with 1761 net eni
AndrewB
Aug 2003
165
Hi
Im having a wierd thing with a 1761 NET Eni hooked up to a SLC503.
Basically the PLC & eni are setup exactly the same as others i have around the place. (I use the same file and just change the IP to set them up)
I can get online through the ENI either through the network or by pluggin in a Xover RJ no worries.
as soon as i get online it hard resets itself (ethernet side of the eni only), it then powers up lets me connect and continues on this loop forever.
seems strange as nothing has changed and it was working fine..
anyone come across this before?
Have a machine that has a Mitsubishi fx32u-32m plc and a ABB Power Supply in the machine that is part number CP-E 24/0.75 It is a 120vac powered...
3,480
At the site I am at I am converting several 90-30 plcs to RX3i. While I am here, the customer had me look at a problem with one of the 90-30...
18
8,562
Hi All.. We have a little problem at the plant I work at... we have been in contact with techconnect and not really achieved much so far.. just...
3,328
Writing a lights control for a church, and just started receiving the error pictured when I do a Verify Project. I can Verify File for each of the...
1,519
Hi! I have a strange problem I can't come up with a solution to. I have a TONR in my program set at 7 minutes. When the timer reaches 7 minutes...
2,335
