wifi Hotspot (Portable)
mad4x4
Mar 2009
ST CYrus
363
Looking for recommendations for a small portable WIFI / Wired Hotspot box thing that I can use when travelling, sort of thing that will allow it to be connected to Hotel WIFI or phone hotspot and then create a Wired / WIFI network so I can connect Laptop etc to it. Had hell of a trouble with the last hotel I was in as my FIRESTICK wouldn't accept the SignIn Page of the Hotel( but my laptop would) .
Battery may be better, but USB powered would be fine.
In addition to the TPLink shared above, I've also heard people say they've had good results with this:
https://www.amazon.com/GL-iNET-GL-M...a-403a-923c-8152c45485fe&tag=ospwareableus-20
I haven't personally used it, but I have heard it's decent for the price. I've been meaning to get one for a while now. You can look up similar products by searching for "travel router."
EDIT: I worked on a project recently that had a wifi router inside the panel that allowed me to connect wirelessly and it was really convenient.
Travel router plus! See my HooToo link..
I really like my HooToo... does A LOT. (It is not as dedicated to Ipad/Iphone as it leads you to believe, works with my Android also...if you are wondering about that part of it).
Yes I also use as a WiFi connection to PLC also.
https://www.amazon.com/HooToo-Wireless-10400mAh-External-Performance/dp/B074LHG47K
I remember you post this a while back, unfortunately, they have been unavailable for a long time.
We have several of those GL.iNET ones, they are excellent. I like that they are USB powered, they are fairly low current, so you can power them off of a PanelView Plus USB port, for example.
That's neat, never thought of doing it that way. Not every panel has a receptacle in it so I wasn't sure the best way to go about using one in those situations. Obviously not every panel has a HMI either, but it's still an option when there is one.
Anyone have experience setting up one of these GL.iNet routers?
So far, I have configured the WAN port for Static IP on the same subnet as the PLC, 192.168.2.xxx. I have RSLinx configured as Ethernet Devices, with the IP of the PLC. This seems to work but perhaps there is a better way?
That sounds like how mine is, though I think I use the LAN port not the WAN port. Is there something about that setup that you don't like?
I have mine set up in 'Router Mode'.
I am not able to get mine to connect on the LAN side.
The only disadvantage I see is having to set the IP to the same subnet each time, and change my RSLinx adapter. Although I'm not sure how to get around that.
Mine is in Router mode too. You can change it so that the WAN port is just another LAN port. Under More Settings, LAN IP, you assign 192.168.2.x, then start IP and End IP addresses. I assume this is the same as yours.
I use one of these and swear by it. Battery lasts anywhere from 1-3 days depending on how heavily you're using it (it's very smart about switching to low power mode when nobody's using it). USB-C charging, physical ethernet port, and takes a SIM card so you can have internet everywhere.
It just gets thrown in my laptop bag every morning when I'm onsite so that no matter what I'm doing or where I am, I have an internet connection. I can also configure it to let me wirelessly commission equipment by putting it on the same subnet as the PLC's I'm working with, and plugging in the ethernet.
I believe that it can also act as a WAP for a plugged-in ethernet internet connection - will use the ethernet internet if it's available and switch to 4G if not - but I've never specifically used it for that.
On the expensive side, for sure, but time is money and having one of these in my bag at all times has probably saved me hundreds of hours.
So my company decided to kill Wifi on the shop floor because the mechanics were all watching YouTube or soccer/football games. The factory is...
6,511
I need an enclosure for wifi access points that will be outdoors. The antennas will mount outside the box but everything else inside. Standard...
158
Hello, I want to establish LTE communications (2 S7-1200) with common Workstation. All i have is 1200CPU with 6GK7243-7KX30-0XE0...
325
Have a project coming up which will use a tablet HMI in addition to the two fixed panels. Curious if anyone has a tablet/router/AccessPoint combo...
1,401
I have a customer that wants to make a system. Think garage door opener. That functional part is simple. They want to connect it to the customers...
1,646
