WIFI Thermostat
CaspianSage
Jan 2017
Where I Am
128
Greetings Friends
We are monitoring thermostats using an input to a dc input card on a PLC-5/20 - The PLC sends an alarm if the heating devices do not start within a certain time frame or the set point is not reached within a predetermined time.
We use the thermostats to turn on a relay to send the 24 signal to the PLC using the PS in the PLC cabinet for the 24 VDC signal.
This is a bit off topic for this forum but I have searched in vain to get some straight answers on a myriad of other sites and since this site is loaded with some pretty smart and experienced technical people I thought I could get the best answer here so please forgive me in advance..
We are looking for WIFI or Wired network thermostats that do not require a cloud service to remotely control using a smart phone or PC
Anybody have suggestions? Not really too concerned with price but we would like to know all options.
Thank you!
I too have used Controllbyweb and they offer great products.
As far as the UI goes add a Maple System Hmi with all the controls you need/want then allow the people who need to manage - remote access. This work very well and still give you 100% control over the system. "No Cloud" is needed!!
I would like this to have a PLC solution .. perhaps cloud based? There is an existing 6 zone in-floor heating system (boiler, with it's own...
2,586
I need an enclosure for wifi access points that will be outdoors. The antennas will mount outside the box but everything else inside. Standard...
157
Hello, I want to establish LTE communications (2 S7-1200) with common Workstation. All i have is 1200CPU with 6GK7243-7KX30-0XE0...
318
Have a project coming up which will use a tablet HMI in addition to the two fixed panels. Curious if anyone has a tablet/router/AccessPoint combo...
1,400
I have a customer that wants to make a system. Think garage door opener. That functional part is simple. They want to connect it to the customers...
1,643
