WinCC 6.0 Script.exe Memory Leak Problem
Datty.Dee
Jul 2007
Yorkshire
Hello all, I am new to WinCC & would greatly value any help or pointers in the right direction that this obviously knowledgeable forum can provide.
I'm having great problems with a number of WinCC5.1 stand alone projects that have been migrated to WinCC6.0. Previously the PCs ran Windows 2000 with WinCC5.1, now they are running Windows XP SP2 with WinCC6.0 SP4+HF2 (Version 6.1.2.2)
These projects all use GmsgFunction to output machine status messages from the PLCs to text file located each machine's local hard drive. The problem I have is that when these migrated projects are running scrpit.exe grows in size starting at 15MB growing to 86MB in about 12 hours and carries on increasing in size. If there are no machine messages coming through script.exe does not grow. If I switch off the alarm logging module (in WinCC) again Script.exe does not leak, but the machine messages obviously don't get written to the text file either!! In WinCC5.1 these projects ran without issue & there were no memory leaks. All the scripting has been done in C.
Has anyone encountered a problem like this before? I have searched the Siemens forums extensively & I can find no reference to memory leaks in script.exe, the only reference I have been able to find is on this forum to a similar problem with WinCC5.1, however the suggested fix of applying an MS fix (KB828741) can't be applied to XP SP2 machines!!
The other problem is that every minute a message is dropped into the text file containing a cumulative count of items produced on the production line, again read from the PLC, however this message can be upto 4 minutes before any machine messages with a similar time stamp are written to the text.
These PCs are built according to Siemens build instructions have 2.8GHz Xeon Processors with 1GB RAM & large fast RAIDed SCSI drives.
Any help anyone can provide will be greatly appreciated.
Kindest Regards
Datty
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
77
Hello Experts I am working on a project with WinCC Unified v16 PC system and want to create an option on the screen to export logs to the...
65
Hello, I have a quick question. I have been using scripts to change the color of buttons. The reason, I am usually using multiple hmiruntime.tags...
120
Hello all, In an WinCC Professional v15 application I need to filter the alarms by alarm class, not using the filter button on the toolbar of the...
2,593
Hi everybody.We want to an application via C script.The scenario is ; there is a silo.Goods into the silo and empty when filled.There will be a...
1,316
