WinCC 6.2 read from AB Logix5000 controller using OPC?
dguedez
Feb 2011
Austin
19
Anybody know how to setup WinCC 6.2 OPC to read data from AB Logix5000 controller? I'm aware there is a way to do this using rslinx as an opc server? An example WinCC project would help.
I think i got it figured out
Ok so it seems, after installing rslinx on the same machine, WinCC was able to find the RSLinx OPC server using the System Parameters of the OPC group > OPC Item Manager.
Hello guys, Im using a siemens with WINCC in a computer and need to import to tag´s data fom a specific row in a SCV file, i have a working...
1,692
Hi all, I wanna Connect Glofa G7m LS PLC to WinCC Flex i have no Serial port in my laptop so i use USB to serial converter and...
2,509
I am trying to find out if there is a way to "read" the tag comments in WinCC Flex 2008 (SP3) during runtime. I'm using WinCC Runtime on normal...
3,861
Hello, I would like to make a script in WinCC 7.2 to read and write data from internal binary tags to specified bit in external(TCP,MPI etc.)...
1,548
Dear All, I need urgent help on the following issue about WinCC: I have button which once clicked will run the following script to read contents...
6,321
