wincc 6 getting out the data from sql server 2000
kovi838406
Aug 2006
romania
How can i get out the data from sqserver 2000. I have some tags and i want there values. In what intervals is the program stores the value of the tags? In which table sould i look an what is the structure of the table ex. tagname ts value ? something like that?
would you like the data to be archived from the WinCC tags to the sql databse, or you want to read data from the sql database to the wincc tags???
If you wont to read data from SQL without connectivity pack you need to save them in TagLogging Slow. If data are stored in tag logging slow they are not coded so it is eazey to read them. So go on:
Tag logging->Archive Configuration->TagLoggingFast->Archive contents
1.unmark acyclic measured values
2.cyclic meas. values with cycle set on 1×500ms <-------------
Tag logging->Archive Configuration->TagLoggingSlow->Archive |
configuration |
1. time perriod of all AND single set on MAX cca 5 Gigabytes |
2.cyclic meas. values with cycle set on 1×500ms |
Acquition cycle of each tag in Archive MAST BE > 1×500ms------
on the end you need to reset archive:
Archive Configuration->TagLoggingSlow AND TagLoggingFast->RMB-> RESET
Go on EXCEL-> Data->Get externel data->New database query-> <New Data Source> .....
So i have a tag in wincc and when i run the projeckt the tag has different values. I created an arhive for the tag but in sql i dont find the...
3,335
We are using wincc scada WinCC system software V7.5 SP2 , connected to few plc . Past 3 weeks we getting this alarm continously when we checked...
87
Hello Experts I am working on a project with WinCC Unified v16 PC system and want to create an option on the screen to export logs to the...
37
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
69
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
70
