Sql Wincc getting out the data
kovi838406
Aug 2006
romania
So i have a tag in wincc and when i run the projeckt the tag has different values. I created an arhive for the tag but in sql i dont find the values of the tag. Where can i find what values does the tag had? Example can somehow i manage to get out the value of the tag with an sql select in a fixed time. like the tag beetwen 2am -4am had this values.In which table can i find the values of the tag.
In the tutorial (on your CD) there is an example how to make a connection between your WinCC application and your SQLServer of WinCC. I ones wrote a manuel for it but I think it's in flemisch. I'll check it.
Rudi
How can i get out the data from sqserver 2000. I have some tags and i want there values. In what intervals is the program stores the value of the...
6,859
Hello all! I have a problem with data logging from winCC to SQL server. I am trying to write a single variable type "Real" to SQL server. The...
2,722
I'm little stucked and ask for small help from one with little more experience of vb script. So, I have alarm control window Control1[Alarm...
1,551
Hi all, I'm trying to connect WinCC Pro to SQL server through OBDC. Everything is okie, I'm able to transfer number, DateTime and even a direct...
1,448
I am new to WinCC and have limited experience with SQL servers and databases, but I have been presented with a problem with the overwriting of...
1,308
