WinCC Adv TP900 simulator
userxyz
May 2002
any
2,768
Anyone knows why the simulator messes up text when simulating an TP900?
Windows settings ?
Thanks,
Kind regards,
C
I know the simulator uses Windows language settings for things like date/time format, and comfort panels have their own separate region settings, so display can be different for those things.
No idea why text sometimes appears different, curious to hear other experiences
Screenshot
Screenshot
Show us a pic
But it probably has to do with tp resolution vs your pc
I had this befor with a PC runtime too. In simulation it was messed up while using the Runtime showed it the way it should. On panels it is also not the first time I have this problem. It only happens in simulation, downloading to the panel does not show issues.
Resolution Laptop is 1920 x 1080
Resolution screen is 800 x 480
This can be caused by windows desktop scaling (in Control panel > Display).
If it's set to something other than 100% the simulator seems to get text sizes wrong.
Scaled
I tried 100% instead of 150% scaling, restarted the runtime (not the laptop). But same issue.
Kind regards,
G
Hi, I appreciate any help to make connection between AB DF1 Micrologix 1200 and WinCC Adv project (PC station - not HMI) possible. For now I can...
605
Hi Guys. When a domain user is logged in (simatic logon erver) both audit trail and alarm logs are working well. but as soon as the user is...
1,495
Hi, I am programming a WinCC RT Adv HMI for the operator workstation PC. The problem is that whenever I create a screen, a series of function...
1,598
Hello, Could somebody please guide me towards the download links for Siemens WinCC Comfort / Advance V13. I tried downloading from the official...
3,907
Hey folks! Just upgrading to Portal and completing install and got a querry. When you install WinCC, there are two DVD's. After the first DVD...
16,848
