Wincc alarms and trends
farrei
Aug 2007
pakistan
60
Dear freieds
I am feeling problme in Alarms and Trends In Wincc
1 How i can increase the capacity of trend storing and how i can see the pervious trends up to last 1 year or more
2 i am feeling problme in alarms data base a: when i delete a alarm line from alarm logging and make a new alarm at that line it shows both when this evet happend it canot delete complete from data base but delete from alarm logging window
any boody guuide me
thanks inadvance
Archiving tags in WinCC
Hi there
1)How far you can go back in trend view depends upon following:
a)How much hard disk capacity you have and how much you have configured.
b)How frequently you are archiving the particular tag
If you are archiving the less frequently and you have alloted enough space then you can go back as possible (a year or two year), like that
2)That alarm will go after either the segment time is complete or when alloted disk space is filled.In both cases overlapping starts, and old data is gone forever.
Also read "Archiving Process Value" in WinCC help.
120 GB hard disk i am using for archiving
Can i transfer this archiving data to an other hard disk and i get print when i need
if yes then how
Hi, Is there a tool out there to convert exported CSV files from HMI Alarms to new WinCC tags with alarms ? Kind regards, C
1,402
iam using wincc v6.0 and i have problem that alarms shown with no time the time appear ( 00.00.00 ) the check box of alarm logging in start up...
1,215
Hi all, I have a strange problem with a WinCC version 7.4 project. If alarms from the alarm list are used, the connection between WinCC and PLC...
4,755
Hi Guys. We are working with a IPC477D PC panel and a 1515 CPU. We got this requirement that there shall be Username on all acknowledged alarms...
1,345
Recently we've had a machine replaced for a new one but different manufacturer. I've been involved in interfacing with PCS7 DCS and so far I've...
5,494
