WinCC and S7-300/CP343 Communication Problems
dlbrown06
Jan 2009
Toledo, OH
Hi everyone! I'm new to the forum and I'm hoping you all can help me with the problem I'm having.
I am trying to communicate between WinCC and a CPU 315-2 DP Siemans processor through a TCP/IP connection.
PLC SIDE:
I think I have everything configured correctly as far as I can tell. The PLC has an IP address and is running.
WinCC SIDE:
I have added the SIMATIC S7 PROTOCOL SUITE channel to underneath the Tag Management section. Then under the TCP/IP channel, I added the driver with the PLC's IP address and the CPU's rack/slot number. Then I added a tag with the address to the DB value I need.
I then created an IOField in the Graphic Designer that should be dynamically connected to the PLC tag.
It doesn't work. When I activate the project, the value on the Graphic designer doesn't update to the value that is on the PLC. Also when I go to Tools->Status of Driver Connections, it shows that the driver is still disconnected.
Does anyone have any ideas?
Try this
Under s7 protocol suite>right click>system parameter> go to the unit tab- under the logical device name- make sure you use the correct ethernet card in your PC.
If you have used Step7 before this will look familar
It is NOT CP-TCPIP
Yes it is. From the Control panel:
Access Point of the Application:
S7ONLINE (STEP7) -> TCP/IP -> NIC Card
^ That is the same as it is set for my TCP/IP channel in WinCC
So under connections you have RACK 0 SLOT 2 in WinCC right??
Just curious- is Step7 installed- if so, can you connect to the PLC?
Yes, in WinCC I am using RACK 0 SLOT 2
I have Step 7 installed. I am not familiar enough to know exactly how to connect to a PLC from it, but from what I gathered quickly...
I went to STEP 7 -> NCM S7 -> Diagnostics
From there I can connect to the Ethernet Card on the PLC. However, in the "Connections" section, it displays, "No Informative Available in this view."
Does that help?
Well, I tried to think of all the basics
Im sure it is something simple though.
Call the Siemens Hotline
1-800-333-7421- its free
Hi everyone! I'm new to the forum and I'm hoping you all can help me with the problem I'm having. I am trying to communicate between WinCC and a...
2,971
Hello! I have an old system s7 300 and with Wincc RT Professional.Windows PC with Wincc RT got crashed and I want to up the SCADA on new PC. I...
2,030
Hi, I have a PC with WinCC 7.4 and a PLC 315-2DP with 343-1 card. I cannot get connection to the PLC in the tag management while settings of the...
2,109
Hello, I'm Alex from Spain (sorry for my bad english). Firstly, I'm a newbie at Siemens PLCs and HMI, I have been reading this forum for hours...
1,605
Hi Everyone, I want to know how we show the profibus slave alarm in wincc flexible 2008.when any one profibus slave do not communicate or give...
3,667
