WinCC Basic v13 Status Msg Bar
timryder
Feb 2007
Macomb MI
176
Hey All,
First time using WinCC and first time using the new TIA Portal v13.
I have a license for Basic and what i was hoping to make was a status bar across the top of each page which would display the basic messages I'm interested in showing. I'd like them to be linked to a tag which will dictate what message is show... of if I have to I suppose I could logically replace the string value of the message?
Got any ideas what tools/controls to use to accomplish this?
That's a regular IO field. You need a "Symbolic I/O Field" which is the the third object under elements (2 to the right of the regular IO field.
Cool,
So then the Tag value can be just an integer and that value will be what is displayed from the text list?
Cool,
Exactly! And if you set up/import multilingual texts, it displays it in the active language, automatically.
One other note: you can embed both tags and text lists into a text box, but it isn't obvious how. In addition to typing text into the box in the properties, right click for additional active options.
So you can add a tag variable value into a IO Field? Like you could do...j
Major Fault (MD1000) Active and whatever the value of the MD1000 is would be displayed?
Awesome TIP!
Awesome TIP!
Text box, not an io field, but yeah, that's the idea!
I’m a bit stuck on HMI (KTP-1200) programming… See the picture attached. The PASS or FAIL box should only appear when the toggle switch is...
1,097
Hi Does anyone know if WinCC basic version has functionality in it for ACCESS CONTROL? By that, I mean we want the HMI to have a lock-out...
1,188
Hello all, The title explains what I need, how can I setup WinCC V14 and RSLogix Emulate500 so I can read/write values from the HMI to the PLC...
3,025
Current state of configuration: PC is connected through PC adapter v5.1 to S7 CPU-400. Program is made with SIMATIC Manager and is working...
3,527
Hi, I have just switched to using TIA Portal Wincc basic and am trying to get to grips with setting up alarms for my HMI basic panel. Surprise...
5,399
