WinCC data archiving
sylwek
Feb 2004
Poland
26
hello,
We have a computer with WinCC 5.1 and there is the need to periodically data backup for this computer.
We have made HDD Ghost disk image, in the event of failure HDD to restore system.
Now the need to periodically back up the database.
WinCC is installed in c:\Siemens\WinCC
the WinCC project is on d:\WinCC\xxx\xxx.mcp
Which files are database files that I have to burn to DVD disc when I will be doing a periodic backup of data?
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
68
Need to add new tags to some recipe inside a Wincc Tia Hmi . Do we have an option to download the recipe , with the newly added elements ...
244
Trying to get data types (AS Structures) to update after a new tag import is made from PLC. WinCC can show red if an existing element was removed...
275
Hi colleagues.We do data logging system.We want to record three temperatures under a certain condition. We prepared the project as follows. We do...
759
I'm a bit stuck again... See the redacted picture. At the moment, pressing F7 saves the "live" laser measurement into the boxes indicated by the...
1,079
