Wincc data tags to Excel help please
Blue Fox
Feb 2013
Basildon
49
Hello all,
I am using Win CC v7.2, I would like to do a couple of data and information transfers to either ecel or csv ortext files onto the pc wincc is running on and also try and send an email of a report at a scheduled time every day:
1. I have approximatly 150 tags being read from a couple of different PLC's these are all numeric values (floating point) used as paramters for the plant I would like at the press of a button on a page to transfer all of these tags into an excel sheet or csv file or text file not too worried which as yet,
2. I currently create a report of the alarms on wincc, I would like to automate this so it is scheduled to report twice a day (end of shift) I would ideally also if possible like this to be emailed to a couple of different email address automatically.
Any help anyone can give me with part or all of this would be a great help.
Need to add new tags to some recipe inside a Wincc Tia Hmi . Do we have an option to download the recipe , with the newly added elements ...
246
Long story short, I am trying to map a DWord-type PLC tag as a Real-type HMI tag. I have a structure that stores arbitrary data, so depending on...
3,581
Recently we've had a machine replaced for a new one but different manufacturer. I've been involved in interfacing with PCS7 DCS and so far I've...
5,500
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
73
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
78
