Wincc Error
userxyz
May 2002
any
2,768
I'm trying to set-up a Single-user project
But, I can't, I get the Error (HResult Error, 0x80004005: Unspecified error)
What can I do ?
Maybe this will help, or at least point you in a direction that can.
Q: Why do I receive an "HResult Error 0x80046127" when opening a SIMATIC WinCC V6 project ?
A: The HResult Error occurs if the security mode of the SQL-Server was changed from "Mixed Mode" to "Windows Authentication Only".
WinCC uses a SQL-Server-Login in order to establish a connection to the SQL-Database. If the security mode is changed to "Windows Authentication Only", WinCC can no longer access these databases.
The following steps show how to change the security mode of the SQL-Server to "Mixed Mode".
Setting up "Mixed Mode":
  1. Open the SQL Server Enterprise Manager via Start > Programs > Microsoft SQL Server > Enterprise Manager.
  2. Extend the "SQL Server Group" positioned on the left side of the navigation window by clicking on the + symbol.
  3. Use the right mouse button to click on (<Computer name>\WinCC) and select Properties.
  4. Change to tab Security.
  5. Select Authentication > SQL Server and Windows.
  6. Confirm the requests to restart the SQL-Server.
  7. Now it is possible again to open projects with WinCC
We are using wincc scada WinCC system software V7.5 SP2 , connected to few plc . Past 3 weeks we getting this alarm continously when we checked...
90
when i tried to go online, why its showing lie this
96
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
116
Hi, At the moment, If the user fails to provide a valid username/password, the image attached appears "Invalid password or user name. Logon has...
1,593
Siemens question: If communication between HMI and PLC fails, how can I detect that in the HMI? I thought it would show some kind of error by...
16
3,950
