Hello,
Currently I am developing a Visu application for an MP377 in WinCC Flex 2007, and I have run into an issue with transferring the project to the HMI. The transfer is via MPI with a 5512 card from a laptop.
Every time I try to do a transfer to the HMI, I get the following error message in the output window:
“The transfer tool could not be found.”
System.Runtime.InteropServices.COMException (0x80040154): Retrieving the COM class factory for component with CLSID {5D0CE850-D909-11CF-91FC-00A0C903976F} failed due to the following error: 80040154.
at Siemens.Simatic.HMI.Utah.Transfer.transferService.CreateTransferServer()
The transfer settings of the panel and the PC have been double and triple checked, not sure what I am missing.
I have made succesful transfers of the same project in the past, albeit with a different PC. The laptop I am using has just recently had WinCC Flex 2007 installed, as I had to load my personal laptop with WinCC Flex 2008 for a different project. I can’t find anything about this on the Siemens website, but I have a feeling it may have something to do with a different PC and a fresh load of the WinCC software?
I am very new to the Siemens world, so please forgive me if I left out some important information.
The laptop I am using is loaded with S7 V5.4.3.1 and WinCC Flex 2007 Advanced.
Thank you,
Chad
Thank you,
Chad
