Wincc flex 2007
Bhayata
Jul 2009
Gauteng
I am doing some trending using wincc flex on a PC with runtime.My problem is that when I switch to run time my screen displays the trend on a 1/4 of the screen only. In all other aplications including Wincc flex my sreen is normal.
I have attached 2 pics I hope someone can help me .
Thanking you.
Check in Device Settings.
Default resolution is 640x480. Change this to the actual resolution of your screen.
Also if you don't want it full-screen, you can de-select full-screen mode.
Additionally, you cannot fill the entire screen on a widescreen monitor (16:9). All WinCC Flex PC RT screen resolutions are 4:3 (i.e. 1024x768 and 1600x1200)
Thanks guys after adjusting the resolution it looks better but I think I will get a smaller monitor it wil look better.
Hello Folks, to my problem: I have a installation of WinCC flexible 2008 (with save as version wincc 2007 option) on my local PC. My project is...
7,742
6,954
I have read many ways of how to use scripts to log alarms to the hard-drive or MMC card on a MP270 and Runtime systems. But what I can't find is...
23
6,926
Hello, Currently I am developing a Visu application for an MP377 in WinCC Flex 2007, and I have run into an issue with transferring the project...
10,219
Hello, can anyone tell me an easy way to sum 7 tags (dint) in wincc flex 2007? and what can i do if i want this summation under a condition?
1,378
