WinCC Flex Project corrupt ?
userxyz
May 2002
any
2,768
I have on several projects the following problem:
Can this be solved in some way ?
Older versions do not have this issue, but since 2016 I have this on several project ?
Thanks in advance,
Kind regards,
Combo
Tia
Hello,
On all systems indeed.
But my VM's at home are different, I will try on my VM's this evening.
The systems here have Simatic and TIA installed together. On my VM's it is seperated.
Kind regards,
G
Same problem on other computers with same projects ?
Hi Combo, might be worth a shot but have you check file permissions for that whole folder, right click on the folder and make sure your current user logged on has file read/write permissions.
Do you have a zip version of the project that you can retrieve?
Older versions of SQL? or older version of projects could you be a bit more specific with that statement?
I had the same problem and also when I start the software, it cannot load any project, it stays blank when I choose some project and click open. What could be the problem?
More info
Permissions are okay. Older versions are in the same folder and do work.
I retrieved all versions, 2014, 2015, 2016, 2017. All versions are okay until 2015, all versions from 2016 and 2017 have the problem.
It became corrupted and the corruptions is backed up until now.
Okay, yes, I can copy the HMI from and old project and yes this works, I've tried this, but I am not sure that I have the last source software now...
Kind regards,
G
Hi Combo,
If you can retrieve from one old archive, and that works then you might have to add everything again to make it up to date. The only way I know how to compare WinCC Flexible projects is by visually comparing all the screens. Unless you have some sort of change log to help you along the way.
I followed the Noobs guide , but i got stuck at this point http://imageshack.us/f/69/flexible.jpg/ i loaded the Step 7 program then i opened...
7,967
Hi I have a request to use upto 6 wincc flex panels, 1 will be the MAIN unit, others wil be remote, with reduced functionality (2 mimic displays...
4,072
Hello Folks, to my problem: I have a installation of WinCC flexible 2008 (with save as version wincc 2007 option) on my local PC. My project is...
7,729
6,947
How to do this right? Is this possible in general? When OP is integrated in PCS7-project (v. 7.1) problem with OS occurs: 1 In NetPro - "...
6,702
