WinCC flex refuses to start
aikona
Oct 2003
B2220 plaas dorpie
182
From one moment to the other WinCC Flexible refuses to start.No changes to PC no microsoft updates no virus update. Any ideas ???
using WinCC flex 2005 SP1 HF7 on XP .
When I click to quickstart or normal icon on desktop ( or in start menu ) the software starts-up with a picture in the middle of the screen and then vanishes.Nothing appears in the task manager
Eric
Check the licence. It sounds like you don't have a licence or the 14day has run out. If you have a good licence then go into licence manager and try to updated it.
Hi
You can try to start after reinstalling the WinCC flexible.But do this after un-installing the WinCC Flexible.
Again your license may have got corrupted, in this case you can ask for help from Siemens.
Hi
I solved the problem ... I considered to uninstall and then re-install...but I first tried something else :
In Explorer under Documents and setting - 'username' - application data - there is a directory called Simatic WinCC flexible 2005 . I deleted this directory then I did the same under local settings and ..... WinCC restarts no problems.
happy ending after all
Eric
Hi
Eric
Worked a treat - thanks Eric!(y)
I'm continuing my Siemens education. I need some help with compatibility details. My customer has a machine that was made by a company no longer...
4,061
Hello all. I mainly work with Siemens PLC's and panels for our machines. But now I am faced with a pilot project that has to be as price friendly...
9,000
Hi Folks. I have an older application that weighs pallets and prints labels for them. We used to capture the time/date of weighing, but we...
1,632
Hi, I have WinCC Felxible 2008 SP5 installed on my Windows 10. I want to program Simatic panel TP177B using USB transfer cable. But i can't...
2,134
Hi, Is there a tool out there to convert exported CSV files from HMI Alarms to new WinCC tags with alarms ? Kind regards, C
1,407
