wincc flex + rs-linx opc + gprs
balash
Dec 2012
Koprivnica, HR
418
i have on the field ML1200 connected thorough serial port to audiotel mc39i gprs modem. i would like to transfer existing connection which goes through some to me unknown protocol to rs-linx opc through gprs and then connect that to wincc flex. would that be possible, is it simple as plug'n'play and what should i do. i'm more of a siemens guy. not much familiar with AB.
I managed to connect S7-200 via SINAUTS MICRO OPC to a RS View. :) (SIEMENS PLC and GPRS and OPC to AB SCADA).
So i believe that is possible to connect also AB PLC and GPRS and OPC to SIEMENS SCADA.
Open new project in WinCC Flex, create new connection, choose RS OPC from list of available OPCs. If you see and can choose rigth OPC server, then I believe you will have no problems in further steps (creating tags etc...).
seems like trials and errors method. well at least there's nothing to loose while local auto is working. i totally forgot about creating new blank project to test the ideas...
I'm continuing my Siemens education. I need some help with compatibility details. My customer has a machine that was made by a company no longer...
4,042
Hello all. I mainly work with Siemens PLC's and panels for our machines. But now I am faced with a pilot project that has to be as price friendly...
8,989
Hi Folks. I have an older application that weighs pallets and prints labels for them. We used to capture the time/date of weighing, but we...
1,624
Hi, I have WinCC Felxible 2008 SP5 installed on my Windows 10. I want to program Simatic panel TP177B using USB transfer cable. But i can't...
2,119
Hi, Is there a tool out there to convert exported CSV files from HMI Alarms to new WinCC tags with alarms ? Kind regards, C
1,403
