WinCC Flex , setting bit on S5
juanmdx
May 2007
SLP
281
Hi there,
I'm working on a proyect on WinCC Flex for a S5 PLC, the thing is that I need that when I'm on a certain screen the panel set a bit on the PLC, I'm using the action "Loaded" on the Events properties of the mentioned screen, but the value isn't changing, or at least that's what I think, because the value of another variable isn't changing. The program is something like this:
If I'm on screen1(DB14 DW18.2) and DB14 DW5 are 1, then load (and go to certain subrutines) with the value DB18 DW52
So, on my screen1 y have the SetBit when Loaded, then I change the value of DB18 DW52, and then I set the bit (with a button) DB14 DW5.
But my values aren't changing, and I can't see step by step what's going on, because I can only be communicated with one device with the PLC (the laptop on which I've the panel working as a runtime) or the same laptop but reviewing the S5 program.
Any suggestions.
Juan
PD- the button that set the bit DB14 DW5 is something the cliend wants.
Maybe is the adquisition cycle of the button that sets the DB14 DW5, it was on 1s and maybe is too slow, I'll put it on 100ms and let you know if that was it.
But if you have any suggestions let me know.
Juan
If you use TTY (aka AS511) as the online connection, then it is not a good idea to set update rates as low as 100ms. TTY/AS511 operates at a measly 9600 baud.
Is it only the setbit function on the screen_loaded event that doesnt work ?
Well I believe is that one, because I can't be checking which values are changing, the only one I can see in the panel is the DB18 DW52, I think is the screen_load bit, but it can be the DB14 DW5 byte, and if the cycle is 1s maybe I'm clicking it too fast (when I press it it goes to one value and on the release it goes to 0 again) and the PLC can't see if because of the cycle.
-- I'm really just guessing, I can't be making test at all times because is one of the most critical machines here --
Juan
I got to the cycle time because I was checking the values on the "runtime with simulator" and I saw that the value of the button sometimes didn't change due to the cycle time.
the load_screen value and the other ar changing correctly.
Juan
I had a call from a customer this morning who's on site commissioning a system for which I did the HMI in WinCC Flex. The system is a 315-2 DP...
5,019
I'm continuing my Siemens education. I need some help with compatibility details. My customer has a machine that was made by a company no longer...
4,064
Hello all. I mainly work with Siemens PLC's and panels for our machines. But now I am faced with a pilot project that has to be as price friendly...
9,007
Hi Folks. I have an older application that weighs pallets and prints labels for them. We used to capture the time/date of weighing, but we...
1,635
Hi, I have WinCC Felxible 2008 SP5 installed on my Windows 10. I want to program Simatic panel TP177B using USB transfer cable. But i can't...
2,138
