Wincc Flex Structures
cjd1965
Apr 2007
UK
1,659
Hi
I have a DB made up of an array of UDT's (Say DB1, UDT1)
In WinCC I have created a structure the same as UDT1 (Say Struct1)
In WinCC I have made a faceplate and used a category of type Struct1
So far so good, but if I use the faceplate on a screen it shows "DB1.UDT1" as invalid for the property when I try and assign the property to the structure using the PLC datablock picklist/dropdown.
An ideas? (WinCC Flex 2008 SP1 HF2)
Im gonna look into multiplexed tags instead.. any good tips appreciated
I don't use them but I think that is what you need. I think they have some good examples in the "Getting started with WinCC Flex". You should be able to find a link to it on here if you can't find it from the Siemens site.
Thanks Charles
Although WInCC is pretty good I am missing some features from flow blown SCADA that I am used to. Doesnt help I am trialling Inductive Automation too so my brain gets a bit overheated lol
Cheers
Thanks Charles
Cheers
Trust me, once you get the hang of IA, you'll never look back. I can't even tell you how much money I've saved just in development time by going this route.
I'm continuing my Siemens education. I need some help with compatibility details. My customer has a machine that was made by a company no longer...
4,055
Hello all. I mainly work with Siemens PLC's and panels for our machines. But now I am faced with a pilot project that has to be as price friendly...
8,999
Hi Folks. I have an older application that weighs pallets and prints labels for them. We used to capture the time/date of weighing, but we...
1,631
Hi, I have WinCC Felxible 2008 SP5 installed on my Windows 10. I want to program Simatic panel TP177B using USB transfer cable. But i can't...
2,131
Hi, Is there a tool out there to convert exported CSV files from HMI Alarms to new WinCC tags with alarms ? Kind regards, C
1,407
