dogfart
I have an HMI application that has 10 I/O fields set up for input/output with 9999 decimal format with decimal shifted 1. The problem I am having is that each object looks a one specific register in the PLC, starting from V130 to V139. The problem I am having is when I change a value in one of the non V130 fields *(V136 for example), the PLC is showing a change of value in register V130, however the HMI is showing this value in V136??
I split this screen into two, and the V130-V134 is still mis-behaving, however the new screen with V135-V139 seems to be working fine. I am also referencing these tags on another screen for display only so they are I/O fields with only output selected.
Does this ring a bell with anyone?
Thanks in advance
Thanks in advance
