WinCC Flex Windows feel...
userxyz
May 2002
any
2,768
I made an application in flex Runtime for entering batches. Can be stored in csv and transfered to the machine.
But, when entering data in an I/O field, u must ENTER !!! This doesn't give a windows feel where you can give the data and just TAB. In flex u must give the date and use ENTER, when using tab instead, the data is not confirmed.
A customer complained about this.
I have the same problem sometimes. I made a search for my recipe. They enter the name they are searching for and then a search button. When they enter the name they must press enter before the search button or the name is not put into the tag for the search and it doesn't work.
I think you can set a tab order for objects on a screen but I don't know how you would get past the enter problem.
if
If it's not possible, then I think this is a really annoying thing in Flex.
Hi, I have WinCC Felxible 2008 SP5 installed on my Windows 10. I want to program Simatic panel TP177B using USB transfer cable. But i can't...
2,126
I'm continuing my Siemens education. I need some help with compatibility details. My customer has a machine that was made by a company no longer...
4,044
Hello all. I mainly work with Siemens PLC's and panels for our machines. But now I am faced with a pilot project that has to be as price friendly...
8,992
Hi Folks. I have an older application that weighs pallets and prints labels for them. We used to capture the time/date of weighing, but we...
1,625
Hi, Is there a tool out there to convert exported CSV files from HMI Alarms to new WinCC tags with alarms ? Kind regards, C
1,405
