WinCC Flexible - appearence problem
vlad.colesnic
Dec 2006
Bucharest
23
Hello guys,
Did you have this problem with WinCC Flexible?
I made a message field that i use on a page. This field has by default a border that i don't want to see. I entered in properties, representation and i choosed the advanced view mode. Than i entered in properties, configuration and now is enabled the access to changing all the colors of the background, the text and the grid. Anyway,if here i put all the colors to white, the border still appears.
Could anyone ever get rid of that border????
Thanx in advance,
Vlad
Did you try unchecking the 3D box? It is somewhere in the appearance area
Just took a look, and it appears that Vlad is right. The border cannot be removed or hidden in any way.
On the other hand, why is that so important ?
I think that with the simple message view you can disable the border.
You are right, with the simple message view the border shouldn't be there anymore - but this is only in theory because i cannot see it. When i change to simple mode view, i do not have access anymore to changing any colors and the background comes black by default.
This is so important because the program is already built with protool and it runs on other 30 machines, and there is no border there. Now that we must use WinCC flexible (due to the burying of protool) we must convert our old protool software and keep it as much as possible as the original. (this border seems to annoy the customer)
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
319
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
121
Hi colleagues.We do data logging system.We want to record three temperatures under a certain condition. We prepared the project as follows. We do...
767
Hello to everyone. I change the value of a "PQW" with a button in Wincc flexible. The code of the button is defined as M102.0. Value reset...
4,615
Hello Friends I have installed WinCC Flexible 2008 SP5 Update 2. I have open the software, but the Transfer option does not appear. Is It...
1,492
