Wincc Flexible autostart without Windows Explorer.exe
Kasperv79
Mar 2012
Copenhagen
48
Hi Guys.
Im running a windows 7 ultimate 32 bit system win Wincc Flexible 2008 SP2.
In older windows i could just either "kill" Explorer.exe and "start" Explorer.exe.
But in windows 7 it seems not to be that easy.
Any of you know how to do?
information:
The system needs to be able to startup into wincc RT, without user interaction. So after power button is activated it start directly to wincc RT.
to enable Explorer, I have a system screen for administrator where i normaly place a button "Start Explorer"
so both mouse and windows start button must NOT be unable to call the menu bar up...
all this to meet the requirement in CFR21 PART 11 (pharmacy and food regulative)
//Kasper
You mean that the HMI must not allow that the operator gets access to Windows start menu and task bar ?
I so, setting "full screen" and "lock task switching" in the WinCC Flexible settings should do that for you.
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
315
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
119
Hi colleagues.We do data logging system.We want to record three temperatures under a certain condition. We prepared the project as follows. We do...
766
Hello to everyone. I change the value of a "PQW" with a button in Wincc flexible. The code of the button is defined as M102.0. Value reset...
4,614
Hello Friends I have installed WinCC Flexible 2008 SP5 Update 2. I have open the software, but the Transfer option does not appear. Is It...
1,489
