WinCC Flexible - computer operating
rQx
Oct 2010
Trelleborg
1,051
Hi!
Our customer wants to operate his machine from his computer.
In TIA there is only WinCC Basic if I have understood it correctly.
I figured out you have to have WinCC Flexible to be able to program the HMI to a computer. Here's my question.
There are several programming programs. Micro, compact, standard, advanced.
Do I have to have the advanced edition to do this?
and
My customer need a WinCC Flexible RT on his machine?
Your WinCC Basic is not directly compatible with WinCC Flexible RT. So you would have to rewrite your HMI program from new if you plan to use WinCC Flex RT.
The next version of TIA Portal that includes WinCC v11 can open your v10.5 project. You then also need to upgrade WinCC to the "Advanced" version.
The next version of TIA Portal will come in 2-3 months.
We are just in the starting of the project so now we just gather the information on what programs to be used. So no worry on any rewriting, we order the flexible advanced and the runtime license and we are good to go =)
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
346
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
125
Hi colleagues.We do data logging system.We want to record three temperatures under a certain condition. We prepared the project as follows. We do...
772
Hello to everyone. I change the value of a "PQW" with a button in Wincc flexible. The code of the button is defined as M102.0. Value reset...
4,631
Hello Friends I have installed WinCC Flexible 2008 SP5 Update 2. I have open the software, but the Transfer option does not appear. Is It...
1,504
