WinCC Flexible/ProAgent How to use correctly: @ErrOpSym1@ @ErrOpCom1@??
tysky
Aug 2011
Silesia
Hi all!!!
For two days I'm trying to solve my problem, but I'm still not able to understand what's wrong.
I have some PLC and one HMI. I would like to visualiazate graphs which are implemented on PLCs. I configure my sequence FBs and messages with "Block Settings" option. In my project I use only Supervisione Error, so I define messages as follows:
PLC1_Suprvision-Error: S@1W%03u@ @1W%t#S7GraphFB11@ @ErrOpAbs1@,@ErrOpSym1@,@ErrOpCom1@
With three last commnds I set that I would like to see absolute address, comment and symbol of conditions which blocks current step. Those settings work only with some sequences, some don't display comment and symbol, besides of the symbol and the comment I have "?", so for example:
PLC1_.....DB110.dbx16.0,?,?
What may be wrong ??
Thank you for any advice
Leszek
I opened a project where I used ProAgent. On the left you can see DIAGNOSTICS: In WinCC Flexible I could not find DIAGNOSTICS. Only when...
8,422
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
304
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
118
Hi colleagues.We do data logging system.We want to record three temperatures under a certain condition. We prepared the project as follows. We do...
765
Hello to everyone. I change the value of a "PQW" with a button in Wincc flexible. The code of the button is defined as M102.0. Value reset...
4,606
